Another noise thread
Angel12
Toronto
Hey all!
Well as of lately I've been hearing this Clicking sound every-time i come to a dead stop and right when i hit the gas the jolt of acceleration triggers a loud click. If it were something loose and clicks into place.Rear passenger side had auto parts guy ride with me and he said it might be a loose U-joint? Will try to get a vid up it might help but any-thoughts would help.
You should be able to get the same results (noise) by shifting between reverse and drive, with your foot on the brake. Can you?
My first guesses would be the U-joints or engine mounts.
Checked under and it seems the rear bushing is broken or what my neighbor seems it might be its cracked in half and the one on the other side is full intact
Angel,
What was the result of this? What did you do to fix it, if anything? I appear to be having a similar problem upon braking and acceleration
Thanks
CJ
I tightened the bolt in which the bracket sits on torqued it about 2 full times and yeah was surprised it was just that...
