Another No Start thread
Lincoln LS
  1. MercuryLs
    MercuryLs Well-Known LVC Member
    249
    Jan 25, 2006
    Lawrence
    Well this is my first post in the LS section.
    Ok, here is the story:
    Picked up a 2000 Lincoln LS v8 with a bad engine and no keys. Got a known good engine for it (and installed it) and had a locksmith come out and program 2 new keys for it.
    After I finished installing the engine and hooking everything back up, fired it up to check everything. It ran well for a few min then suddenly shut off? Check fuel pressure- good. Now it just cranks and cranks, but never starts! I also have acess to the SCT software, so I tried disabling the PATS in the tune- still no luck. I have "noid lights" that plug into the injector harness to see if they are "pulsing"- they are NOT. So I tried replacing the crank position sensor- no change.
    So before you ask:
    Fuel pressure- good
    Crank Position sensor- changed
    PATS light flashing- No
    Injectors getting a signal/"pulsing"- No
    Cranking over- yes
    Does it even try to "fire"- No
    Any ideas???
  2. joegr
    joegr Dedicated LVC Member
    19,600
    1,433
    Dec 10, 2005
    Gulfport
    What if you unplug the MAF sensor, will it start and run then?
  3. MercuryLs
    249
    Jan 25, 2006
    Lawrence
    No.
    The injectors are not receiving a signal to "fire" (or "pulse"). Im assuming the coils are not firing as well- though I haven't checked.
    Typically if the injectors are not "pusling" the first thing that comes to mind is the crankshaft position sensor or Antitheft. I have ruled both of those out.
  4. LS4me
    LS4me Dedicated LVC Member
    9,966
    272
    Apr 23, 2004
    San Diego
    Why have you ruled out the PATS? IIRC, a locksmith doesn't have the tools to "marry" the keys to the system. Don't the keys and cluster have to be paired?
  5. joegr
    19,600
    1,433
    Dec 10, 2005
    Gulfport
    Actually, some/many locksmiths do have the tools. The one I have (which will do that and more) was only about $400.
  6. joegr
    19,600
    1,433
    Dec 10, 2005
    Gulfport
    Okay, how about the fuses? With the key on, the positive side of each coil and each injector should have +12V. The PCM grounds the negative sides as needed. If you don't have +12V with the key in run, you probably have a blown fuse or bad relay.
  7. joegr
    19,600
    1,433
    Dec 10, 2005
    Gulfport
    If the MAF reads no airflow, then the PCM won't inject any fuel. However, it should still pulse the injectors a few times during the start attempt.
  8. MercuryLs
    249
    Jan 25, 2006
    Lawrence
    Figured it out. PCM harness was not 100% tight. Running now!
Share This Page
