After searching for blend door problems, I can't seem to find my problem. What is usually find is no heat or no air. This is what mine is doing:
When the air is on max cold, I get cold air (max cold air on 60 deg setting). If I take the air up to 65 deg (the next setting up), I get heat... max heat. There is no middle of the road... either max hot or max cold. I have ran it like that for two years, but would really like to fix it right.
Is this a blend door problem????
