OK, Here's the scoop. First check out Quik's post located here:
http://www.lincolnvscadillac.com/showpost.php?p=414151&postcount=2
I printed out the instructions he linked to located here:
http://www.lincolnvscadillac.com/showpost.php?p=29316&postcount=2
I'll refer back to his picture later on for orientation on removal
So, first from the top side remove all engine covers and the intake tube. This is a very simple process.
Now, get your 3/8" breaker bar out. The square end from your breaker bar fits right into the tensioner arm. Pull to the passenger side to get the belt slack and slip it off the alternator. The silver bar coming right at you in the pic is the breaker bar.
You are now done up top. Jack it up and put it on some jack stands, or use ramps so you can get down and dirty.
Underneath remove the splash guards. It takes a very small socket. I of course don't remember which size.
Now we have to move the AC line out of the way. It will continually be in your way throughout the process. So, undo the clip and remove the screw on the bracket (driver side front) so you can easily swing the line back. Don't be afraid to really push it back out of the way when you need to. Quick was smart enought to zip tie his out of the way on his picture (refer to the first link at the top).
Here's my new (to me) alternator. It has two spots where it mounts to the car. In the upper hole you will have a single through bolt with a nut on the back. Reach up and remove the nut and push the bolt through the front to get it out. The bottom uses two bolts which go into the threaded holes on the alternator. Remove the back one and the front one. The front one has a bushing that is permanently connected to it. Don't try to remove the bushing. It is supposed to be there.
Now the fun part. Pry the existing alternator loose and jimmy it around so you can get to the connectors. Make sure the battery is disconnected, then take off the positive lead with a small socket. Then unplug the plastic connector by pushing on it with a screwdriver.
To remove the alternator you have to make sure the AC line is as far back as possible. Look at the picture Quik had of how to position the unit for removal. I had a difficult time getting it out like that. Instead I positioned it so the pulley was up and the rear of the unit was down. (sorry no pic) It worked much better for me that way.
Once the unit is out take a look at the mounting brackets on the car. A bushing may have pushed inward which will make it difficult to put the new unit in place. If that happened do your best to bang it back into place with a hammer, or whatever else you may have handy.
Now reverse the process and you should be golden. Enjoy another frosty beverage in celebration.
Ah, yes. Looks like I've been working on the car again. . .
