I am running into an issue with my air ride. I have seached but can not come up with this exact problem.
Car is sensor lowered and has Rays kit on it.
1. While driving, the rear bags will vent for no reason. I do not get a check susp light (ever).
2. After the bags are vented, I will shut off the car, restart it and the compressor will only run for about 15 seconds.
3. I've tried to manually vent the bags (with the kit) and restart, but the comp still only runs for about 15 - 20 seconds... just long enough to fill the front bags.
4. The rear solenoids click about every 5 seconds when venting (venting on its own). After I shut the car off, it will sit there and vent about every 5 seconds until empty. Does not do this all the time... really random.
I have removed Rays kit and still have the same problem. Thought it might be associated with the kit.
Also, if the rear bags are up, and I turn the air ride off, they do NOT leak down (nor do the front). I know they do not leak.
I NEVER get a check susp message unless I vent the bags.
I know that's alot of info, but thanks for any help.
T
T
