~~ABS question fellas???????
fastmarkviii
palm bay
after I did my lower control arm today my abs light turned on, I took the battery cable off and left the key on to try to reset it but it didnt work,,, while I was changing the control arm I noticed the other line to the caliper (not the fluid line) was very extended..... any ideas?????????
you know, the same thing happened with mine when i changed to coils...i havent gotten arround to figguring that one out yet...i too am interested.
You could try to check if the wire is broken but, chances are that you may need a new ABS sensor.
so how much does a abs sensor usually go for?
abs is overated....ill prolly kick myself for that
besides, i like not having to turn off TC
yep.... you probably broke the wire. These things are REALLY sensitive, especailly the wires.
I think I have a couple of front sensors in my tool box somwhere...let me check. send me a pm reminding me tomorrow.
Mike
