97 Mark VIII
Rich88LSC
Long Island, NY
1997 Mark VIII base Evergreen over Prairie tan 85K miles, interior is clean for age mileage. A couple guys on here have seen/been in the car and can vouch for the condition/maintenance of the car.
Since I've had the car I've replaced the following...
New head gaskets
Valve cover gaskets
Granatelli COP connectors with new boots
Just replaced two COPs today
IMRC controller replaced
new water pump
oil filter adapter gasket
front main seal/front cover gasket
tensioner with pulley/idler pulley
Gatorback belt
new from Ford headlight housings for 9006 bulbs
replaced shorted neon housing(debadged)
"Glitch" ballast
fuel filter done today
rear wheel bearings
front upper and lower control arms
all four air bags
transmission professionally overbuilt(550HP) with high performance parts
Circle D 10" 3500 stall convertor
transmission cooler installed
Dynotech 4" aluminum drive shaft
rebuilt entire rear end with 4.10s and brand new Trac lok.
Xcal2(comes with car) with performance tune for 4.10(also have tune for stock gears)
rear mufflers deleted, factory tips still there
sensor lowered
IAC replaced
BFG Traction T/As in factory size 225/60
Car does not need brakes now but I have pads and at least front rotors possibly rear rotors too that can go with the car.
Have SVT fuel pump I may let go with the car as well.
The bad:
clear coat fading on roof.
small trans fluid leak, I have a new rear seal as well as a 1-2 shift spring if you want to tone it down.
emissions tray under trunk is rotting out however I have one in nice shape you can have.
Asking $4000, make an offer if you want but no low ballers. PM me for phone number.
Car is in Suffolk County Long Island
I have personally been in the car. It's a very fun car to drive with all tranny, gear modifications and best of it all - the interior is in an outstanding shape.
Good luck with the sale Rich.
