Here's what I did to gain manual control over my air ride system. This all began when the factory compressor took a dump on me and forced me to install a set of coils for awhile. During that time I read every writeup that had to do with aftermarket air management on our cars. I chose paddle valves because they are cheap and reliable. They mount inside the car and use 1/4" air line. The do not freeze and are less sensitive to debris. Electric valves are cool too but they would have exceeded my promise to my ol lady budget. In the end I decided on the following:
4 manual paddle valves
1/4" air line
Nickel plated ptc fittings
2 dual needle gauges
5 gallon aluminum tank
Viair 144c
Drain
Pressure relief valve
1/4 ball valve and chuck for air tools
Schrader valve just in case of comp failure
4gauge power wire
Inline fuse
Distribution fuse block
Various terminals
Okay first up was figuring where to mount the paddle valve setup. After numerous hours of sitting in my car and planning how I was gonna plumb 6 airlines to feed it...the only natural place was in the center console. I made a card board template and cut a piece of plywood for the panel. I sanded the edges to get a perfect fit then stained and glossed it.
1/4" air line
Viair 144c
Drain
4gauge power wire
Inline fuse
Various terminals
