1995-97 Lincoln Continental Security Information
Constant 12V+ Black/Orange Ignition Switch Harness
Starter Red/Blue Ignition Switch Harness
Ignition Brown/Pink Ignition Switch Harness
Ignition 2 Gray/Yellow Ignition Switch Harness
Ignition 3 Black/Light Green Ignition Switch Harness
Accessory Gray/Yellow Ignition Switch Harness (Heat/AC)
Tach Dark Blue/Light Green Top of Coil Pack
Brake Switch Green/Red Brake Switch
Trunk Release Black/Yellow (-) Switch
Trunk Pin Brown/White (-) Passenger's Kick Panel or LCM behind Driver's Dash
Parking Lights Brown Light Switch or Driver's Kick Panel
Head Lamp Brown (-) Light Control Module behind Driver's Dash
Hood Pin n/a
Factory Disarm Dark Green/Purple Driver's Kick Panel
Door Trigger Black/Light Blue Driver's Kick Panel
Door Lock Pink/Yellow Driver's Kick Panel
Door Unlock Pink/Light Green Positive Trigger
Horn Wire Dark Blue (-) Steering Column
Windows Up LF=Red/Yellow, RF=Yellow, LR=Brown/Yellow, RR=Brown/Yellow
Windows Down LF=Yellow/Red, RF=White/Black, LR=Brown, RR=Brown
