Bossed
As some of you may remember, I've had trouble trying to diagnose a #3 cylinder misfire issue. I took it to the dealership to see if they could figure out what was going on. The technician did a compression check, checked the PCM, tried different coils, swapped injectors, all the electrical stuff checked good as well as the other things he checked. He said theres one more thing he can try, but he's starting to think it could be a valve spring or maybe a camshaft. I replaced the secondary timing chains and tensioners before the engine was installed in the car, when doing so I did'nt have any trouble. I was wondering if any of you had seen this before? Any help would be appreciated!
Bossed
Bossed
