2002 Olds Silhouette
Blair
Katy
Got a problem with the drivers side headlight .... it's more like an aquarium. there is literally standing water in it, i assume there is a bad seal somewhere, and this seems to be a common problem with these cars, anyone familiar with it?
Maybe it would be easier to go to a boneyard and pick up a cheap replacement? I know that doesn't really answer your question, but that's what I'd probably do.
been looking, local picknpull only had 3 matches, and all the headlights had already been pulled. :)
small drill bit at lowest point on underneath side of headlight, will let the water drain right back out. Likely the seal where the lense is attached to the housing, pretty common on all newer style headlights. Get some silicon or epoxy and run a bead over the seal.
