You can get access on-line to the factory service manual for your 2002 for $11 for three days here:
http://www.helminc.com/helm/product...esult&Style=helm&Sku=FCS2002LSWEBD&itemtype=N
SECTION 211-02: Power Steering 2001 Lincoln LS Workshop Manual
REMOVAL AND INSTALLATION
Pump —3.9L
Special Tool(s) Teflon® Seal Replacer Set
211-D027 (D90P-3517-A) or Equivalent
Removal
Remove four pushpins and the engine cover.
Remove the air cleaner and the air cleaner outlet tube. For additional information, refer to Section 303-12 .
Remove the bolts.
Remove the accessory drive belt. For additional information, refer to Section 303-05 .
Unclamp and disconnect the power steering reservoir-to-pump hose (3691) and drain the reservoir (3E764) into a suitable container.
Position the power steering reservoir out of the way.
Loosen the bolts.
Rotate the reservoir from the insulator.
Pull the reservoir down from the insulator and position the reservoir out of the way.
Raise the vehicle on a hoist. For additional information, refer to Section 100-02 .
Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
Remove two bolts, one pushpin and the shield.
Remove two pushpins and the shield.
Remove the bolt.
Disconnect the electrical connector and the wire retainer.
Remove four bolts and position the A/C compressor out of the way.
Disconnect the power steering pressure hose (3A714).
Remove the bolts.
Lower the vehicle.
Remove the bolts and the pump (3A674).
Installation
Using the appropriate special tool, install a new O-ring on the power steering pressure hose fitting.
NOTE: Do not tighten the upper bolts until the lower bolts are installed.
Position the pump and install the bolts.
Raise the vehicle.
Install the bolts.
Connect the power steering pressure hose.
Position the A/C compressor and install four bolts.
Connect the wire retainer and the electrical connector.
Install the bolt.
Install the shield and two pushpins.
Install the shield, one pushpin and two bolts.
Install the wheel and tire assembly. For additional information, refer to Section 204-04 .
Lower the vehicle.
Tighten the bolts.
Connect the reservoir.
Push the reservoir up on the insulator.
Rotate the reservoir on the insulator.
Tighten the bolts.
Connect and clamp the power steering reservoir-to-pump hose.
Install the accessory drive belt. For additional information, refer to Section 303-05 .
Install the bolts.
Install the air cleaner outlet tube and the air cleaner. For additional information, refer to Section 303-12 .
NOTE: Inspect the pushpins for cracks or other damage. Install new pushpins if necessary.
Install the engine cover and four pushpins.
Fill and leak check the system. For additional information, refer to Section 211-00 .
