2001 LS Antenna Reception
EricY
Kitchener
Is the antenna in the 2001 powered by a 12V accessory? If so, what wire in the factory harness do I need to apply the 12v to?
I installed a Kenwood KDC-X397 head unit a couple months back and have been super happy with my install, except for my poor radio reception. Since then I recently had to get a new motor installed so the radio has taken the back burner, now that its running again I would like to take a look at the issue. My local audio shop said that its probably because I didn't wire power to the antenna (He owned a 1st gen LS back in the day), I have also considered installing a new Hidden Antenna and putting it in the passenger A pillar. Thanks.
there is no "power antenna" wire that needs to get powered up like a lot of cars do...
I actually did read through all those posts ahead of time. I looked around that problem spot in the headliner and didn't see any of the usual suspects. The poor reception started right after I changed my head unit so I doubt the timing is a coincidence. I will take apart my head unit soon and see whats going on back there. (maybe could be a loose connection) Thanks for the quick help! :)
