The tail lights all work sans the three brake lights. Connectors look fine, no moisture in there or any of that. I checked the fuses located in the trunk, are there others up front or inside that I may have missed?
When you go to shift from park to reverse or drive with the engine running, does that work? If it does, your brake light switch is okay.
What happened just before the brake lights stopped working?
To clarify, you're asking if the brake lights light up briefly when the gears are shifted to drive or reverse? Just took it off of the ramp, They didn't light up at all.
If it's not the fuse or the wiring, it'll be the REM.
Will an REM swap require flashing from the dealer?
Last and final question guys, I don't mean to be a bother. I searched google and the forums for this and couldn't find an answer.
Where is the REM located? How can I access it? I just need to verify the part number before I order the replacement.
Fuses and brake switch look fine. Should I replace the wiring harness at this point? It looked fine when I inspected it earlier... could it be shorted despite it not appearing burnt out?
Did you get them fixed my 2000 is doing the same thing.
Only if the replacement REM is not from an LS of the same configuration.
Hi All,
Is there a way to tell if the REM configurations match? I will probubly get a replacement REM via junk yard or part out. If the model numbers match is it good to swap between vehicles?
