jrod
Where is the crank position sensor located on my Lincoln. I want to fix whatever is wrong with ASAP. It breaks my heart to have it just sit it the garage. Thanks!
jrod said:Where is the crank position sensor located on my Lincoln..
I HAVE A 96 AND I HAVE THE SAME PROBLEM I GOT A BOOK FROM CHILTON AND IT SAYS THAT THE CPS IS LOCATED ON THE SIDE OF THE FRONT TIMING COVER IT IS KINDA HARD TO GET AT. I CALLED THE DEALER AND THEY SAID IT WOULD COST ALMOST 300 FOR PARTS AND LABOR. I BELIEVE THE PART IS BETWEEN 30 AND 60 BUCKS. SO IT HAS TO BE HARD TO GET AT. IF YOU KNOW HOW TO CHANGE IT LET ME KNOW AND IF I FIND OUT I WILL LET YOU KNOW. THANKS AND GOOD LUCKjrod said:Where is the crank position sensor located on my Lincoln. I want to fix whatever is wrong with ASAP. It breaks my heart to have it just sit it the garage. Thanks!
MARK01 said:I HAVE A 96 AND I HAVE THE SAME PROBLEM I GOT A BOOK FROM CHILTON AND IT SAYS THAT THE CPS IS LOCATED ON THE SIDE OF THE FRONT TIMING COVER IT IS KINDA HARD TO GET AT. I CALLED THE DEALER AND THEY SAID IT WOULD COST ALMOST 300 FOR PARTS AND LABOR. I BELIEVE THE PART IS BETWEEN 30 AND 60 BUCKS. SO IT HAS TO BE HARD TO GET AT. IF YOU KNOW HOW TO CHANGE IT LET ME KNOW AND IF I FIND OUT I WILL LET YOU KNOW. THANKS AND GOOD LUCK
MARK
MARK01 said:HEY JROD I JUST FIXED MINE TODAY AND I FOUND OUT EXACTLY WHERE IT IS LOCATED AND WHAT COULD BE UR PROBLEM. IF YOU PULL OFF YOUR PASSENGER SIDE FRONT WHEEL YOU WILL SEE THE HARMONIC BALANCER AND TO THE REAR OF IT IS A ELECTRIC PLUG IN IT HAS A BOLT THAT HOLDS IT IN AND THAT IS THE CRANK SENSOR. IT IS EASY TO REPLACE. BUT YOURS MAY NOT BE BROKEN IT JUST MIGHT HAVE A FAULTY CONNECTION. I WIGGLED MINE AROUND A LITTLE BIT AND THEN I STARTED MY CAR AND BOOM IT STARTED UP. IF IT IS BROKEN YOU WILL MORE THAN LIKELY HAVE TO ORDER IT FROM THE PARTS STORE. I DID THIS BEFORE I FOUND OUT IT WAS A BAD CONNECTION AND NO PARTS STORE AROUND HERE HAD IT IN STOCK THEY HAD TO ALL ORDER IT EVEN THE DEALER. AT ADVANCE AUTO PARTS IT WILL RUN YOU AROUND 30 DOLLARS AT THE DEALER IT IS A LITTLE MORE. IF YOU NEED ANY MORE HELP FEEL FREE TO SEND ME AN EMAIL HOTFITCHGUY01@YAHOO.COM. I WISH YOU THE BEST OF LUCK MAN. MARK
