redcatman74
Problem:
Had intermittent problem with losing brakes (both check brake and brake warning lights on at the same time). The problem would go away and then come back.
Took it to a Goodyear dealer to get new pads, and new fluid.
Problem with intermittent lose of brakes continued and then was permanent.
Currently I have no power assist brakes - very hard and ineffective brakes - Car is unsafe to drive like it is.
pump does not turn on
So far I have:
read posts on abs and tried to follow recs as best I could.
Checked relays and fuses - seem to be ok
put code reader on, at the check brake light I got two flashes, long pause, one flash, pause, and then constant on - not sure if that is a 21 (main valve) or 22 (left front inlet valve)
At this point I don't know how to proceed. I don't have a repair manual (trying to find one even though I don't know if it would help).
Anyone have suggestions on where to go from here. I hate to think I may have to junk the car.
Also, is the brake system on the 1988 Lincoln Town car the same as the 1988 Mark.
Thanks
RCM74
So far I have:
Thanks
RCM74
