Gees guys I made a funny below and nobody laughed , I hope you all , didn't take that post too seriously ... Ideal block temp is 200 deg for what its worth. I think if the water temp sensor for FI sees 160 there may be some issues with mixture control.. Along with a different opening temp , lower temp t-stats usually have a larger hole for more flow..Drag racing , we always ran on a cold motor starting only when time to run and then off as soon as possible , in some cases we towed from the finish line as not to heat the motor... Then cool off between runs till next elimination.Drag only cars don't have a cooling system...As far as no thermostat at all , it has been my experience that it is possible for the water to pass through the radiator too fast and doesn't get enough time to cool ... Thus water temp ,on hot days in that case , could continue to climb till overheat .I think with todays higher temp motors and smaller radiators this is probably closer to the norm not the exception.. In that case the Tstat controls upper limit also...I think under normal conditions with the proper size and functioning cooling system a 180 deg tstat should maintain 180 degrees ,plus or minus 10 degrees...I have found the engine temp to remain very constant in my car under all conditions, both highway and stuck in traffic.. What that is I am not sure Guage has no numbers , but I would guess 195..Guage damping might have some effect on small variations but not more than a few degrees..You guys running no Tstat and high temps with small tstats may have radiator flow problems...Just a thought ...
