Okay, my 03 LS V8's electric cooling fan comes on after 5 minutes of diving, even when it is 60 degrees F outside and raining. I had the dealer replace the coolant, put in a new thermostat, bleed the system. I took it in again for a pressure test and a rebleed. No air was in the system and no pressure leaks.
The fan whines so loud that it can be heard at freeway speeds. It sometimes slowly winds down to half speed if I sit and let idle a few moments, like when I get the mail. The car is not overheating at all. Does this sound like a coolant temperature sensor, or a fan with it's own mind, or what? HELP cause I want to give the car to my son before I go to Iraq, but don't want him to inherit a bunch of problems other than coil issues.
Thanks
Thanks
