anyone know where the low pressure port on a 2004 LS V8 is? The high pressure that you can't use is conveniently put on top in front with nothing blocking it.
It's on the compressor manifold right next to the compressor. Look under the left front of the engine through the wheel well area. There is a plastic splash shield you may have to remove but can probably work around it.
