I would avoid the cheap knock-offs for trying to go wireless.
https://www.amazon.com/gp/product/B07JFRFJG6
I have been using this one for a few months with 0 issues and it has circuit protection built in that won't fry your pcm. It works with forscan and forscan lite with 0 issues. Also, this is the one forscan recommends to use.
They say this one is ok as well if you use an android device. But I would go with the first one if you can swing the difference as it has it's own app that is pretty good. Plus the first one works fine with a PC using forscan.
https://www.amazon.com/dp/B08FSXYXLG
