04_Sport_LS
Because then anybody could do it. Even the ones that are a danger to themselves.
I don't care what the receipts you have say... because they seem bogus... like the mechanic padded his time so he could make more $$$ on an easy repair.
He probably did replace all the control arms... with cheap aftermarket ones. The easy way to tell that... is because the OEM ones will have a "Ford, Motorcraft, or Jaguar" badge cast into them...
and will typically have the part number on the control arms too.
You are way overthinking things and making this harder than it has to be. Reminds me of someone else on here.
I just called my local dealer and gave them your VIN #. So I did YOUR "leg work" for YOU.
They said the knuckle/ball joint is 14mm, but is obsolete. They also said that there WAS a conversion "kit" that converted everything over to the 16mm ball joint... but that is now obsolete too. THAT might be why FPG is showing 16mm lower contol arms... but the ball joint isn't part of the contol arm on an LS.
The conversion kit would have included a new knuckle, lower control arm, rotor, and wheel hub (not spindle)... but as I said... it is obsolete too.
So... you have 2 choices. Get an aftermarket knuckle (which includes a pre-installed 14mm ball joint)... or call FPG and triple verify that they actually have the original knuckle assembly in stock. (which would be a miracle at this point)
AGAIN... the ball joint is part of the knuckle... NOT the control arm.
