Cferrell160
My windows will not work I have checked the fuses. They are good I was told that there is no way that all the regulators would stop working at the same time. Does anyone have any advice
I can push the door lock they only lock half way I don't know which ssp relay would work the windows all other fuses are goodYou checked (with a meter, not just visually) fuse 22 passenger side fuse box, fuse 19 in the trunk, fuse 20 in the trunk, fuse 30 in the trunk, and the SSP relays?
Is anything other than the windows not working? Are you sure they all stopped working at the same time? When was the last time that each of them was used?
If you hold down the unlock button on the remote (key off) for a few seconds, do any of them open?
Does your moon roof work?
Yes there is none of them work. The motors does not make any noise at all the do not dimDid you check the other switches?
Do the motors make any noise? Do the lights dim for a second if you try to roll them up?
Turn the key to the Run position, but don't start the car. If the fuse is blown, pushing a window button will do nothing at all: The motor won't groan and the glass won't quiver. If the fuse is good and you can hear the motor, or the glass acts like it wants to move, then you've got some sort of mechanical problem...My windows will not work I have checked the fuses. They are good I was told that there is no way that all the regulators would stop working at the same time. Does anyone have any advice
Turn the key to the Run position, ...
Whoops Yeah I meant accessory position ...thanks JoeThe windows on the LS work just as well from the accessory position, and that has less things powered up and making noise.
One of my complaints with the Hyundai is that the windows only work on it from the run position.
Was this changed for Gen 2? Gen 1 fuses list the FEM for the front passenger window (REM for rears and DDM for driver). Gen 2 lists the front motors together but doesn't specify a module. Maybe something about the express up/down on both sides? I can look at the wiring diagram laterThe driver's door window is powered and controlled by the DDM. The other three windows are powered and controlled by the REM.
