1992-1997 it's a analog signal, this was changed from 1998.
Here is a guide to check the MLPS Manual Lever Position (MLP) Sensor
It's easy to disconect, but take care of that there is an adjustment of the unit. Just elonged slots for the screws.
How do you disconnect the MLPS ? Does it pull off or is it bolted on ?
The MLPS is covered with oil and other buildup so it's difficult to see what's holding it in place. It's an original part and I want to avoid breaking it.
2 bolts and the electrical connector.
The MLPS doesn't like water or other fluids, so just wipe it of with a rag.
Check the adjustment before you take off the MLPS.
