tireman
There is a "C" shaped linkage item on the throttle body held in place by two small plastic sleeves. These sleeves crumble over time. Where do You get new ones? The dealer says you have to buy a new throttle body. Not so! These exact same little plastic sleeves are used elsewhere on the engine. I asked the Ford tech to search the schematics and show me the parts, yes exact matches found, used elsewhere on the engine. Now the bad part ,$16 dollars for two little plastic sleeves!!!!!!! So next I go to Lowes Home improvement store and check their hardware section and guess what? Almost identical sleeves for $.50, and you can actually use these sleeves. I posted this because I saw others having the same problem.
