Hey everyone, so my Mark 8 had to unfortunately sit for the past few months due to the nasty Winter full of rain and ice, during these months I managed to kill a battery from it sitting, I would at least boost the car once every 2-3 weeks to keep the fluids flowing and rust off the brakes, went to go put it back on the road with a new battery and it started ran like a champ, parked it and let it sit a few days again and go to start, nothing but relays clicking under the dash and a check engine light no crank at all, found the relays by going in through the glovebox and underneath the steering wheel they appear the all by the same "F0ab 14b193ab" swapped them around and still won't start, tried resplicing positive and negative cables with new terminals those appear to be fine as well battery has good voltage all fuses relays are fine, visually looked at the starter and observed no rust or corrosion on it there is no clicking coming from that, I did notice in the glovebox there was a lot of moisture build up...took a hair dryer to it to dry it out but still no go, anything I might be missing here before I go digging around with volt meter? No antitheft light either unless I mess with fuses so I don't think I can blame that yet at this point either
