LS with LSD
ninjafied
canada
So I've been trying to fit a LSD in a second Gen LS rear end and I've run into a problem, well actually a few problems. The LSD is from a Ford Ranger. The Crown gear from the LS fits the LSD from the Ranger no problem, but there were some clearance issues fitting the whole unit back in the LS rear end. After a bit of grinding on the housing the diff slipped in. The next problem I'm having is the Axle on the passenger side does not fit in all the way. Im guessing I'm using the wrong style of LSD.
https://photos.app.goo.gl/Jc5cHb2MthQfGUP4A
I hope the link works I'm having trouble uploading pictures
I read somewhere on here that it wasn't possible to fit a Trac Lok into a second gen housing. The Trac Lok will fit in the first gen housing and the first gen housing will bolt on a second gen LS. But you need first gen axles too. That's what I have on my second gen LS.
