AmsterDutch
Lady Luck was on my side with the Master Cylinder component and I was able to bleed the brakes successfully...however I’m in the same deliama that I was in at the start of all these problems ...Caliper bracket is rubbing on rotor ...I’ve researched and found some ppl say it may be due to bad bearings in hub ...any thoughts? I’m unfortunately breaking down with this brake problem and will be bringing it to the stealership on Monday evening if my fellow LS owners can’t steer me in the way to tackle this problem ...just for your information...the scraping is worse when turning left and my dust plates have been removed three months ago when I changed out hub assemblies and lower ball joints ...I thank all my fellow LVC members in advance
