subwoofer amp
MikeSchwed
New York - Upstate
I bought a 2002 LS which is missing what I think is an amp for the rear deck speakers. I believe I've read that they are subwoofers, not 3 way speakers. Any advice on finding a new amp or replacing the subwoofers with regular speakers and amp would be appreciated. 2 empty plugs hanging in the trunk, not sure if they are stock of if the PO had something else in there.
Here's a photo of what I have
Those are stock connectors, but whatever is going on with the red barrel splices is not.
Thanks. Found what I think is a stock amp on eBay, we'll see
The stock amp expects to drive two ohm subs, which are not extremely common. The factory subs are still available though.
At least the red barrel splices aren't a nondescript wad of electrical tape. Without seeing the whole scheme of things it might be a tap to a high level signal for an external amp? Maybe even a low level signal depending which pins are being hooked up to. I doubt anybody would go to the trouble of reinstalling the factory rear deck speakers, so could have been an amp and sub in there at some point ????
