.Can anybody identifty this part
DomSouth
Sioux city
okay does any body know the actual name of this part. ? If yu never seen it ill inform you. So its from a 5 speed manualLincoln LS. ITS WHAT PUTS THE CAR IN IT'S GEARS. so yu got 1 . the selRector/shift Knob.2. shifter/selector arm 3. an a shifter/selector ROD.. SO THis part is what the ROD INSERTS IN THEN SECURED WITHA MINI CLAMP.
it is stamped with a T look in pics i point it out . not sure y . it does resemble a letter T in a way an so it sits on the RIGHT ABOVE THE DRIVESHAFT COUPLING. AN I AM NOT SURE I THOUGHTJT WAS WELDED TO TRANSMISSION BELLHOUSING BUT IT SEEMS TO BE SECURED WITH A DOWEL PIN
i been to all auto stores they a dumbfounded. saying nevrr seen it. i havent been able to fabricate a part similar to it or found a dowel pin that is the right diameter.
Please identify it looks to be the only way illfind it or anything thatis similar thanx.
see its not that part either thebpart isnt listed. its the thing E425 is locking, to
Yeah, doubt they sell it separately. You may have to pick that from a junkyard.
