Supercharging 98 Mark VIII LSC
Well I just dropped off my forged short block, fr500 Roush yates Daytona prototype heads, etc... to the guru for assembly. Stay tuned in. Terminator bumper has been ordered as well and the frankenswitch just came in.
Build is still going down. The engine should be completed shortly. Custom audio system is being installed at my local audio shop now. To be continued......
Good luck.
Mine took a dump. Hoping to have the motor back in by the end of July. If not I am going to turn it into a pig roaster...
they will.
but there are also better options.
fr500 duration is not so long, and b heads like duration.
im hardly an expert.
if youre on Facebook, look up the NA SVT cams and intakes group. tons of great info there.
if you arent about that life, look up cam recommendations for 96 98 b head cobras. NA SVT is on pretty much all the forums.
on the cheap, 96 98 cobra intake cams are an easy drop in.
if you start to get more wild, you'll need valve springs as well.
