93mark8rules
I'm getting 4 ABS codes and I'm trying to make sense of them. The codes are 31, 32, 36, and 76. All of which point to bad Left and Right Front ABS sensors I finally brought it back to Pep Boys today to try and solve the problem. Well it turns out that both sensors test at 1.080 k ohms so they're in spec, and the wires going to the sensors from the computer have 5 volts across the pins, what can be causing my code? The part that bothers me is this only happened after Pep Boys changed my strut rod bushings.
