93mark8rules
I have a 94 Mark VIII and I recently got a check engine light that goes off at idle but comes back on when accelerating. Also I noticed the car is a little down on power. I scanned it and got code 214. I did some searching and found out that 214 can be caused by a dead coil pack, bad cam sensor, or bad ECM. Now last summer when I bought the car it ran horrible and was showing something like 12 different codes. Until I found the real problem I replaced a ton of parts. But the ones that matter here are that I changed, the spark plugs and wires, both oxygen sensors, replaced one coil pack, and the cam sensor. Ive only put about 12,000 miles on the car from last year to this year, and haven't had to do any recent work so I dont think I knocked a something loose. I checked and all of the coils are firing, but it does have a random miss at idle that comes and goes. Also after a hot restart, if I get home shut the car off and restart it within 5 mins it runs rough then smooths right out. Is there anything else that could randomly generate this code?
