Got turbo ?
Lseme
Bburg
Single or twin ? Who's had success adding boost to the 3.9 ? How much power can stock engine handle ? Is it true the 3.9 has forged internals ?
Turbo got
Single turbo with 25psi.
A turboed LS would be awesome but you'd be much better off starting with a different car.
AJ engine internals are typically NOT forged. The rods are powdered-metal, the pistons are cast aluminum, and the crank is cast as well. The block is a work of art including a significant amount of the sort of features that're found in ground-up-designed race engines.
If you want to start with factory-best, get one of the 'S' engines.
KS
