Name this plug
bigdawgz
hemet
2002 Ls. Base under driver window switch
That's the same part number as is used for speaker connections and also for the horns. Which do you think is more likely?
1. He has a fuel injector in his door.
2. He has a horn in his door.
3. He has a speaker in his door.
D. All of the above and has obvious misfire
I am going to pull the panel the off this weekend and take a closer look
well is there sound coming from that door's speaker area?
