Rear hub redrill
so if you were to use a hub lug change adapter whose hub bore was larger than the marks which they are you would use a hub centric ring around the mark 8 hub to the inside of the adapter so that became as one plate the carrying all the load on the adapter being type with the hub on the mark.
