You'll probably want to stick to FWD cars if using another OEM wheel to keep the correct offset. That will keep the wheels from sticking out farther than they should.
Thank You for your answer! yes i know about the bolt pattern 5x108, but it is not all.
The size of the rim should be : 7x16 with the depth of - (ET) 40
But what about the main pinhole size? (i don't know the English word for it, so i present a pic)
