dnsherrill
on the white car, 96 base
after repairing BDA and reassembling dash and interior I've noticed (with EATC OFF) air is flowing from the dash vent while moving; if i stop moving, air stops from the dash...even with a temp of 50deg outside the air is warm, like it's coming off the engine;
today it's pretty warm (75ish) and with the blk interior it's even warmer in the car; turn to MAX AC.....air blows but not cold; turn to AUTOMATIC set at 65 deg....same thing, lots of uncooled air from the dash, not much if anything from the other registers
it's possible the EATC is from a different car, it is a soft button, so it's either from a 95 or 96
where to start trouble shooting? confirm compressor is coming on? check freon?
the good news: I changed the BDA to have heat, I got that!
