NGK. I know someone here said they like the E3 plugs, but every single person I know who has used E3 plugs has had poor mileage, poor throttle response and a rough idle.
I have e3 on my 2000 v8 for about 8k and no complaints good idle good throttle response
cant really comment on mileage because of my driving style
I would use double platinum or iridium plugs. The stock plugs are mostly NGK.
I thought the stock plugs are Motorcraft. NGK are mostly for Japanese imports.
Better go with OEM. The previous owner of my car used Bosch thinking that the engine was European.
I used Bosch plugs and gas mileage and throttle response went down. Put in Motorcraft fine tip platinum OEM and love them
Half of the stock plugs I pulled from my wife's '06 were NGKs and 6 of the 8 in mine were. This is from the factory.
NGKs were in from the factory on both of my LSes.
NGKs iridium bought and ready for coils to arrive , thanks guys for the input
I got a free K&N FIPK because I drove up to their Development Center a year or so ago to show them that the T-Bird system did, in fact, fit the LS as it did the Bird. As I already had one installed, the freebie has been sitting, unopened in the garage the entire time. Well.... As my wife's LS isn't dur for a smog check until next year I decided to install it. Now both our LSes have the system installed.
What did I do to MY LS? Well.... I bought it. :D Then cleaned it, new tie rods, ordered a clock spring and door handle, got the sunroof closed but the plastic runners are broke so no working roof. :( Also got to figure out why the subs on the rear deck are not working.
2000 LS V8 in dark metallic blue. 202k and just a few thousand on the new motor. Runs and drives great. I really like the car...... I know, send me the hate. LOL
the only thing imma hate on is the signature lol damn mosquito had me going nuts,
very clean car, another Texas LS sweet
ok that makes me feel a little better , it just worries me that i can hear the creak inside as well
the car has no issues stopping at all , heck i barely tap the break and it responds perfectly
the brake fluid is perfect , so im just a little baffled by noise
yes im very nervous when i start hearing any noise in my car
heres a vid i just took, any input guys
just the front brakes make the creaking noise
[video=youtube;Su52qHr-85Q]http://www.youtube.com/watch?v=Su52qHr-85Q[/video]
Holy crap I've been battling this same issue for some time now. Are you telling me its actually the caliper thats the problem? My car brakes just fine as well just that embarrassing creaking noise when I apply the brakes as i come to a stop (and put it in gear). Whats weird is that the noise goes away temporarily every time I bleed the brakes. I even paid a shop to do it (doubting my skills) and although the noise went away for longer than when I bled them, it still came back.
My reservoir keeps leaking fluid tho no matter how low I run the fluid level. Tried new cap as well. Am I missing something?
...My reservoir keeps leaking fluid tho no matter how low I run the fluid level. Tried new cap as well. Am I missing something?...
If you mean minor seepage around the cap, that seems to be normal.
Caliper noise, eh? Something that bugs me about my 2003 LS V8 is that when I come to a stop, right before the car stops it goes taptaptaptap. Sounds like 4 taps, like datdatdatdat, takes about 1 second from stop to finish, low pitched tone, low volume, like taking a ball peen hammer and tapping on a heavy iron pipe full of water. Any ideas if this might be caliper related? As a side note I have to replace the rear tie rod ends still yet, was going to do it this week but the time just disappeared on me.
Well I guess in addition to my other repairs I will also have to replace the HVAC. Noticed no heat on the driver side so I ran codes and it had a plethora. 1342, 1257, 1253, 1261, 1967, 2429, 1947, 1676, 5041. Yay.
Doing the off & defroster then auto gives me these codes. I then do the off & floor then auto and it does its normal testing but shows no error codes.
Those are all stored codes, talking about something that happened in the past. It's possible that all of those triggered when the battery voltage was too low for it to know what it was doing. I would erase the stored codes and see if any come back. You're not getting any failures during the live self-test. It still may just be the DCCV (DCCV does not always set a code).
I am having Sapper grab me the DCCV while he is at the JY grabbing a couple other parts.
Well the JY run was a suedo bust. Got a DCCV but there were no fan pump valves to be had anywhere so I just paid $150 at the dealer. At least he got a fresh arm rest although there were no Alpine sub amps. So it was win/fail/lose/win/lose.
Changed my water pump and belt today, funny thing about it is that I changed the exact same pump in January. Its barely been a year and I didn't start driving the car daily until June.
Thank God for warranty
I changed my front pads today. Kicked my butt! I had to do it out in the sun. 3. 5 hrs with all the breaks and a gallon of water. Pads were pretty thin but no rotor damage. They took about 10 miles to bed in and now they are super quiet and smooth. I got the Brake Best Brake Select Ceramic with the split friction surface for $49.99 at O'Reilly.
Add: I had to go ahead and change the pads when I did. I was actually expecting to find some rotor damage because I had been getting the brake fade and UH-1 Huey sound when doing heavy braking at the end of long off ramps. I guess that was just heat expansion as there was absolutely no rotor damage at all. That's not saying they couldn't use a some lathe work but, with my plans of doing the Jag upgrade it wouldn't be worth it.
Those are good pads. I install a dozen or so per week and after two years I have never had a customer complaint and when they come back for other repairs I inpect them and am always pleased.
Wagner makes all Brake Best Select stuff now including hardware and calipers so its all great stuff.
Those are good pads. I install a dozen or so per week and after two I have never had a customer complaint and when they come back for other repairs I inpect them and am always pleased.
That's good to know. I chose those because they have the split surface which I've had good luck with reducing heat checks on my past cars that had rear drums.
