RiteGroove
Is Suncore the best conversion kit? Add Bilstein shocks to the rear?
Well,what are my options to go the performance route? When I walk out to car in the morning,the front end is slammed to the ground,,Is that an airbag leak? I just dont want to get stranded somewhere,and Ive heard horror stories on what it costs to repair air ride system,
only thing you need still is the rear spring perches
something to center the top of the spring to mount in the car.
Do you make these upper spring perches/mounts pictured here? Do these work with any rear spring either lowered or standard height? Also how does it mount? Or does it just hold itself in place with spring pressure?
I do. They'll work with any springs that will fit an '89-'97 Thunderbird and fit in a Prothane 6-1709 spring isolator.
More info in this thread.
http://www.lincolnvscadillac.com/showthread.php?t=62875
Ok, question..do you need to use rubber isolators with your upper and lower perches? As it is, these ad a little height to the rear if each is 1/4" thick, so isolators would ad to that even more right?
The perches are designed to use the Prothane 6-1709 isolators. If you're using Thunderbird lowering springs F&R, the added thickness is needed as the pockets in the Mark VIII LCA's are deeper than the pockets in the stock Thunderbird LCA's. I originally designed the perches to use in Thunderbirds that had "upgraded" to Mark VIII LCA's, and found that the perch base and isolators were needed to maintain the same ride height in the rear.
Oh ok, that I didn't know..figured the only difference between the thunderbird and mark was the fact that the LCAs were aluminum instead of steel..thanks for the info, Ill be ordering springs and shocks soon, so do you have a supply of these made already or are they made to order?
My setup is going to be Tokico Blue fronts and rears with H&R springs. Already have the blues on the rearend.
