fbird18
Just like the title says, I am having a problem and that is the code the autozone scanner got. I searched already on the subject and all I found was V6 info. The car starts fine, drives and accelerates and shifts fine, but idles like a 84 camaro with aggressive cams
and you can smell fuel outside the car.
The autozone scanner spit this out:
Definition:
Fuel trim bank two condition.
Explanation:
The ECM had detected a rich or lean air/fuel ratio condition on engine bank two.
Probable cause:
1-If bank one and two are set together suspect a fuel pressure condition or MAF sensor fault.
2-Failed HO2S21 (heated oxygen sensor - bank 2 sensor 1)
3-Ignition misfire condition
4-Fuel Injector problem
5-Engine mechanical condtion
(the guy said it was cylinder 4 with the problem, but I don't see anywhere on the printout pointing at cylinder 4)
Is there a good place to start checking things without diving into replacing fuel injectors or MAFs? If it makes any difference, two weeks ago replaced the DCCV. Did the clockspring last week. All injectors and all COPs replaced 2 years ago. Also have 149,00 mi on the odometer. Any help is greatly appreciated I would love to figure this out this weekend.
Definition:
Explanation:
Probable cause:
