Cadillac Car Stereo Replacement1990 - 1995 Cadillac Deville Stereo Replacement |
By: Pepsi2185
Safety Exercise caution when working around electronics and unless you are well versed in automotive electronics DO NOT USE A TEST LIGHT. Although many times it is harmless to use a test light, in only takes one poke to destroy a 5 thousand dollar body controller. |
Identification There are three systems in use for a Cadillac car stereo sound system. The first is the conventional as described in 85-89 deville. In the dash is the Cadillac car stereo and tape deck. The second is the Cadillac car stereo controller is in the dash board and the sound system is amplified by a separate amplifier. It can also in rare occasions be a combination of controller amplified and separate amplifier. Meaning the Cadillac car stereo runs so many speakers and the amplifier will run the other. This system can either be interfaced into or totally bypassed. The third is the Cadillac car stereo where the dash board unit is a display. All sound processing and amplification are done in a trunk mounted module either behind the rear seat or next to the power antenna. Interestingly enough the controller still uses the same harnesses as all 90-late nineties GMs just is in the trunk at the controller. Antenna, speaker leads and power connections must be connected here. Tools Socket set Materials Wiring harnesses
First System Remove the metal sleeve from the aftermarket radio with enclosed keys. Assemble the dash kit according to the dash kit instructions for the model year. You will need the dash kit piece which offsets the radio 1.5 or so inches beyond the point at which the old Cadillac car stereo sat and it will stick out a bit. Insert the ring into the dash kit assembly and bend back the appropriate metal tabs. Connect aftermarket radio harness and wiring harness wires verbatim. Connect the bare ends together. Black to black, red to red and so on. There may be some that are not used such as orange with black etc. Tape those connections off. Don't forget the blue wire or the power antenna will not go up. Plug in the harness to the aftermarket radio along with the antenna adapter and the dash harness and clip radio in to the metal sleeve. Install the radio into the opening and reinstall the trim ring.
Second System Normal amplified All four channels are run by amplifier. With your harness to incorporate into the factory system, get power, ground, ignition, illumination, and power antenna/amplifier lead from here.
brown/yellow - left rear -
green green/black If the harness lines up as above you will have separate low signal positive and negative. If you have the factory harness with a naked wire with shielding over it in between two wires you have the shared ground system. Connect the positive wires to their respective colors in the harness for positive, but either share the negative or have a separate negative. You will need to compare your harness to the vehicle plug to tell which negative to go to. Example. Grey is front right and white is front left. Either grey with black or white with black is going to the be the negative signal lead for both front speakers. Same for the rears. Connect your harness, length of wire and aftermarket radio harness all together matching colors verbatim. Just make sure you connect the input signal properly. Make sure you connect the blue wire at the harness or the amplifier will not turn on.
green green/black where brown, drk blue, green, tan, is positive - green, purple, grey, white is positive Subwoofer Systems If you have some of the newer systems with subwoofers, it will take some testing with a 1.5 volt alkaline battery, low voltage input into the wiring harness and 12 volts to turn on the subwoofer amplifier. Sometimes the subwoofer input is connected in with the other four channels but most of the time it will have its own separate plug behind the head unit.
Third System Nonamplified system - Run the wires from the controller box located either behind the power antenna or behind the rear seat behind the control center. It is the box that has a coaxial cable coming into it. Usually you can trace the speaker wires to the box. Plug in your GM harness and run the wires to the front of the vehicle. This system simply requires you to lengthen all of the wires 20 feet longer. Except for ground which you can connect to solid metal in the dashboard area. Grounds are very important, make sure your connection is a secure ground.
Connect the wires from the aftermarket radio harness to the vehicle harness adapter verbatim including the extension to lengthen the wire. Tape the bundle every so many inches for strength. Amplified system - Run the wires from the controller box located either behind the power antenna or behind the rear seat behind the control center. It is the box that has a coaxial cable coming into it. Usually you can trace the speaker wires to the box. Plug in your GM harness and run the wires to the front of the vehicle. This system simply requires
important, make sure your connection is a secure ground. The only change
is instead of directly connecting the purple, green, white, grey and purple/black,
green/black, white/black, grey/black to the speakers you have to either
connect the RCA's behind the radio to the input of the amplifier as a
low signal input. Or you need to use a premium sound interface. Bear in
mind without the adjustable interface you will get a popping noise as
you change channels and sources. The two front speaker in inputs share
a negative signal and the rear speakers share a signal ground. Connect
but share the negative. You will need to compare your harness to the vehicle
or the amplifier will not turn on. In either system, run the extension harness up front to behind the dash where the radio will go. Assemble the kit and put the radio in the kit. Plug in the radio and test. It may take some custom work to the get the radio to sit right and a little tacky window sealer to hold the Cadillac car stereo trim ring into place.
NOTE: This is in no way a cut and dry install. This is a bit of a complicated install and may be a challenge for one not acquainted with electronic cadillac car stereo systems. The cadillac car stereo kit will take some creativity and custom work with a regular GM kit. |
This area is intended for Tech Tips submitted by members of LincolnvsCadillac.com. The opinions expressed here are the opinions of the individual author and do not necessarily represent the views of LincolnvsCadillac.com. Undertake these procedures at your own risk. If you have any comments or questions please contact the individual authors. Reader assumes all the risk associated with the installation of aftermarket products. LincolnvsCadillac.com and its owners are not responsible for any direct or indirect damage to the vehicle, person or persons and the resulting costs incurred from the installation or use of these products. LincolnvsCadillac.com recognizes that "Cadillac" and "Chevrolet" and their respective logos, model names and numbers are registered trademarks of the General Motors Corporation. These and other terms used on this website are used for identification purposes only. Lincolnvscadillac.com is not affiliated in any way with the General Motors Corporation, Cadillac, Chevrolet, Mobil or any other website or company listed herein. |
