Cadillac Car Stereo Replacement1985 - 1989 Cadillac Deville |
By: Pepsi2185 Safety Exercise caution when working around electronics and unless you are well versed in automotive electronics DO NOT USE A TEST LIGHT. Although many times it is harmless to use a test light, in only takes one poke to destroy a 5 thousand dollar body controller. |
Identification In the dash is the Cadillac car stereo and tape deck.
Tools Socket set
Materials Wiring harnesses
Look along the woodgrain trim piece around the radio for two bolts along the upper edge, if they are there remove them, if not just remove the trim. Remove the Cadillac car stereo. Remove the metal sleeve from the aftermarket radio with enclosed keys. Assemble the dash kit according to the dash kit instructions for the model year. You will need the dash kit piece which offsets the radio 1.5 or so inches beyond the point at which the old radio sat and it will stick out a bit. Insert the ring into the dash kit assembly and bend back the appropriate metal tabs. Connect aftermarket Cadillac car stereo harness and wiring harness wires verbatim. Connect the bare ends together. Black to black, red to red and so on. There may be some that are not used such as orange with black etc. Tape those connections off. Don't forget the blue wire or the power antenna will not go up. Plug in the harness to the aftermarket radio along with the antenna adapter and the dash harness and clip radio in to the metal sleeve. Install the Cadillac car stereo into the opening and reinstall the trim ring. |
This area is intended for Tech Tips submitted by members of LincolnvsCadillac.com. The opinions expressed here are the opinions of the individual author and do not necessarily represent the views of LincolnvsCadillac.com. Undertake these procedures at your own risk. If you have any comments or questions please contact the individual authors. Reader assumes all the risk associated with the installation of aftermarket products. LincolnvsCadillac.com and its owners are not responsible for any direct or indirect damage to the vehicle, person or persons and the resulting costs incurred from the installation or use of these products. LincolnvsCadillac.com recognizes that "Cadillac" and "Chevrolet" and their respective logos, model names and numbers are registered trademarks of the General Motors Corporation. These and other terms used on this website are used for identification purposes only. Lincolnvscadillac.com is not affiliated in any way with the General Motors Corporation, Cadillac, Chevrolet, Mobil or any other website or company listed herein. |
