Stang GT against a VIII?
Lincoln Mark VIII
May 4th, 2008, 03:41 PM
#1
Full Member
My woman was drivin' my '94 Mark VIII, and said some guy pulled up in a mustang and wanted to race. My question is how do Mark VIII's, stock, handle against stang GT's?
May 4th, 2008, 04:30 PM
#2
Full Member
what year? the GTs in the mid ninetys werent all that fast but the new ones have 300 hp. the body style before that have 260 hp i beleive and the bodystyle before that had around 215hp i beleive.
May 4th, 2008, 05:50 PM
#3
Full Member
depends on the year.
__________________
steve. 7+ year ford drivability tech.
95 mark viii 14.3@98, 03 cobra modded, 97 3000gt VR4 modded, 91 stealth TT gutted and modded, 91 mazda b2600i 4x4 lifted, 95 montero SR factory locker and lifted, 95 nissan D21 v6 4x4 stock,
May 4th, 2008, 07:03 PM
#4
Full Member
From what she showed me, my guess is about '96. Is there an engine difference of the 4.6 for the 2 cars? and how much diff in the body weights in the 2 cars performance?
May 4th, 2008, 07:27 PM
#5
Full Member
96/97 are low-mid 15 second cars in stock form. dont worry.
__________________
May 4th, 2008, 07:34 PM
#6
Full Member
VR4,
You say dont worry as if the lincoln will stomp the stang GT. do you know what kind of times are typical of a '94, M VIII?
May 4th, 2008, 07:37 PM
#7
Full Member
Here is a video of me racing my nephew's 5 speed 98 GT vert. He did some mods to it, but not in the traction department
The Mark vs BS3
__________________
Mike
11.751 @ 120.80
SSHS8 Class D
Runner-Up
May 4th, 2008, 07:52 PM
#8
Full Member
Nice run. I looked at the pictures you posted, and I see abig difference compared to my M VIII. Especially engine and exhaust. did you make mods?
May 4th, 2008, 08:37 PM
#9
Full Member
Quote:
2 different engines
the gt has a 2 valve per cylinder 4.6 v8 iron engine
and the mark viii has a 4 valve per cylinder 4.6 v8 aluminum engine.
96 gt has 215 hp and weighs about 3400 lbs
94 mark viii has 280 hp and weighs about 3750 lbs
bone stock race for both cars,the mark should win by a little every time,thats with stick in the gt,if the gt is auto ,not even close
__________________
mike
1995 Mark VIII with 2002 GT trans 1993 engine,1993 driveshaft, a whole lot of miles....
May 4th, 2008, 08:38 PM
#10
Full Member
Thanks. My Mark is way far away from being stock anymore. I thought you would like to see what a standard shift GT does with street tires. Not much of anything in first gear but spin...  IIRC, that GT has 373's, King Cobra clutch, PI heads, headers, etc., and does much better when it hooks at the track.
__________________
Mike
11.751 @ 120.80
SSHS8 Class D
Runner-Up
May 4th, 2008, 10:27 PM
#11
Full Member
VR4,
a typical good condition mark will run about 14.7
__________________
May 6th, 2008, 12:03 AM
#12
Full Member
NPI Mustang GT (1996-1998) w/ M5 trans vs Mark VIII is close enough to be a drivers race. If the GT driver can shift then they will probably edge ahead of the average stocker Mark. It should be a pretty good race.
PI Mustang GT (1999-2004) Will take the average stock Mark no problem with equal drivers. It will not be a a race measured in bus lengths but the GT will usually have a decided victory stock for stock.
__________________
Kenne Bell Supercharged 03 Ford Explorer...More money under the hood than what the G8 cost...bout covers it...
2009 Stryker Blue Pontiac G8 GT...Magnaflow Exhaust, KBX CAI, KBX HP Tuned, Powerbond UDP, Vector HSRK, 100 wetshot progressive nitrous...
2005 Lincoln LS V8...KBX Turbocharged...Sold...
May 6th, 2008, 06:48 AM
#13
LVC Gold Member
the stock 96-98 gt is pretty slow.
the 99 up is pretty quick.
pre 95 is usually not stock and the 93 and earlier stangs are light!
had no problem smoking a 96-8 with my mark and i know it at least had exhaust mods. guy jumped at me,i blew his doors off then slowed down.when he caught back up,the look on his face was priceless !
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Current eBay Auctions - Click to view
