bmiller04107 said:got enough torque to slip the belt eh? good for you
mark0101 said:Are you really going to change the belt by yourself? Cause the belt is PITA to change. I would rather let another person do it unless you are comfortable of doing it yourself. I did it on my mark but at least it had some space to get through the belt. Just giving you a heads up.
aristo1963 said:not hard j but it is a pita.you will have to pull off the right front wheel and move the coolant bottle for best access . slip the belt from the tensioner after making careful note of how it went around the pulleys.the hardest part is getting it clear from the frame just work it down and twist it sideways and work it free.install the new one from the bottom buy working new one in the same way then just route it back into place.
if mileage is high id change the pulley and tensioner set.do not get autozones tensioner it is not the right one.dealer mine was 68 bucks the pulley is arounf 14 bucks az and others do have that one.also a tensioner bar set from az helps greatly as it has a good length and lower profile to get on the tensioner hole.also makes other tensioners easier to do.i changed my last one in around 45 min from jack up to jack down.
john
also they tend to squeel as the tensioners get older and lose strength hence the advice to change it to.
Future said:Why not try cleaning the pullies first? Slipping is usually not enough tension, or dirty/greasy pullies. Chances are you have plenty of tension and it's only a dirty belt. Take some basic toothpaste and rub it on one of the pullies, then run the car for about 5 minutes, gently hose the toothpaste off and see if your problem is fixed.
