1. As you can see -- we got the software change done. Although there is a lot of work to do still, I thought I would open the site back up. If you encounter any problems -- contact me via the "Contact Us" link on the bottom of the page.
    Dismiss Notice
  1. Dustin Kennedy
    Dustin Kennedy Member
    13
    Oct 28, 2013
    Cape Girardeau
    So I bought my LS V8 in May of this year, and shortly after found this site. Ive used the wealth of knowlege and information here to fix the dreaded coolant issues this car gave me, and minor electronic issues. Ive wanted an LS since i was 10 when they first came out, I know what I want out of it and I will not be deterred from that. Im going to build this old cougar into a ferral lioness in heat. Not a swap, not just a tune and intake, Im talking bored out internal overhaul turbo milenium falcon ten grand in this mofo.
    While I do welcome any advise or information, I ask that you do not tell me I cant do something. A man put a 350 and 6 speed in one of these cars, tell me why something may be difficult by all means, just dont tell me i cant do it.
    Ill post pics of the car along with lists of current and future mods soon. I hope to learn from and contribute to the collective comunity, and i hope to retain my sanity over the course of this build.
    More to come!
  2. dannyquest
    dannyquest Well-Known Member
    69
    Dec 2, 2008
    Paterson
    "overhaul turbo milenium falcon ten grand in this mofo." LoL
    -this car is not for you. lol
    anything can be put into something. If you want to spend half that ten grand on a 93 cobra motor, do so. or just spend the cash on the motor internals and get the 80 - 100 hp. The Lincoln is designed (if I am not mistaking) to hand -400hp with the OEMs. Anything more, you risk in putting to much force/torque.
    Please correct me if I am wrong.
  3. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
    Actually I believe compression is the bigger issue with these motors. Regardless, upgrading the pistons, cams, valves, heads, and rotating assembly, make these problems go away. The block can easily handle the power with the right internals, the only issue I am concerned with is if theres enough meat for bulletproofing.
  4. chris2523
    chris2523 93 Mark VIII
    7,384
    Nov 8, 2007
    Central MO
    not much in the way of aftermarket for the Jag V8. so it'll be a whole lot of custom stuff. or creative solutions.
  5. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
    Yeah, the lack of aftermarket is a shame. I havent looked much into it yet, but im hoping i can use parts from the s types aj motor as a basis for some of the custom work. I did get a good look at the block, Im almost certain theres enough meat for bore and bulletproofing.
  6. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
    So here is my LS. Current mods are only an aftermarket air filter, exhaust, 20" Boss rims, and interior. For the air filter I used a Spectre 9345. I removed the stock air box, cut the filter end of the MAF tube, planed the cut end flush with a razor and clamped on the filter. Im currently working on fabricating a heat shield, ram intake from behind the lower fascia, and tubing to replace the stock plastic intake. Most of this should be fairly easy since Im manager for the nonferrous department of a scrapyard, though I havent been able to find decent aluminium tubing. I may just use copper, polished copper looks really great. As for the exhaust, its actually a lack thereof. I was going to install glass packs where the resonators were, but after removing the pipes from where they hook up shortly after the cats, i started it up and liked the sound. Eventually Ill cut out slots a couple inches forward from the rear wheel well and have side port dual tips. As for the interior, the car originally had the truffle interior(sort of beige and grey), until some one brought a green 01 LS in for scrap(blown motor, clearly from lack of maintenance), with fairly nice midnight black interior. I left the top portion of the dash grey, as well as the main part of the backrest for the back seat, and a few minor pieces along with the carpet, to end of with a unique two-tone that i think turned out great. Ill try to get some interior pics and a sound clip soon, along with the current list of plans for building a monster.
  7. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
  8. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
    bought a bmw.... lincoln is for sale lol. $3500 obo
  9. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
    dont drive a bimmer if you arent prepared... theres no going back...
  10. 2000lsv8
    2000lsv8 Well-Known Member
    417
    Feb 2, 2010
    greenwood
    Wow..a whole 3 months and you've given up?
  11. slowmkviii
    slowmkviii Well-Known Member
    4,984
    Sep 28, 2007
    Elk River, MN
    Who didn't see this coming
    Must not have been much of a dream if a BMW replaced it so quick.
  12. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
    Well i got tired of seeing "ford" stamped on everything. That and other things you would have to drive a 6 speed v8 bmw to understand. Anyway the motor is blown up(i use the phrase loosely), but i need to get $2200 out of the car. The rims and tires are included, asking $800 for them alone. 20" Boss 304 with less than 300 miles on the front tires and about 70% on the rear. Body and interior are clean, tranny shifts smooth, everything is for sale. I also have the grey(truffle) interior that i swapped out for black.
  13. dannyquest
    69
    Dec 2, 2008
    Paterson
    I bet my Lincoln would take your bimmer... If you v8 cant slide off 2nd gear take off, you car aint sh*t. lol
    I cant wait for the "overhaul turbo milenium falcon ten grand in this mofo" to his bmw. 3 months later, Dustin switches to a civic. lol
  14. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
    actually dumping the clutch in 3rd breaks it loose. but anyway, glad to see i didn't get too involved in a community of people who say things with such ignorance. you should research the target of your bashing before attempting bench racing. so i got rid of the lincoln, so what? i fail to see the need for this **** talking. yes, i always wanted a lincoln ls, i got one, i was disappointed. if i ever own another lincoln, id probably get a mark 7 and drop a 302 in it. the ls is just too limited in options, with a stock v8 that squeezes too much power out of too little displacement. im sorry to say things you dont want to hear about your car. and a civic? really? so switching from a rwd v8 sedan to another rwd v8 sedan, an e39 bmw, considered by many to be the greatest sports sedan ever made, somehow leads to buying a honda civic? maybe so to a guy that speaks to others like a ricer on some honda forum. i fail to see the logic. i thought people who drove luxury cars were a bit more sophisticated.
  15. JoshMcMadMac
    JoshMcMadMac Well-Known Member
    2,339
    May 3, 2004
    Waynesboro, PA
    Apparently the target of their bashing does not know enough about the car he would buy to know that the Mark VII only ever came with the 302 in it*.
    *Save for the handful with the diesel.
  16. LEOV5
    LEOV5 Well-Known Member
    1,083
    Mar 17, 2006
    So Cal
    Wait till the electrical gemlins move into his BMW.
  17. cammerfe
    cammerfe Well-Known Member
    2,459
    Oct 27, 2007
    Metro Detroit
    It seems likely that Dustin/Justin/whatever doesn't come around very often. Arguing with him is also a waste of time. I hope he remains happy with his choices.
    KS
  18. LS6_5SPD
    LS6_5SPD Well-Known Member
    753
    Oct 6, 2007
    Miami
    That's what makes me wanna keep my LS, cause nobody has a properly built one, there are probably 5 on the whole US, but BMWs? You find them by the dozens, in all colors, ricer looking, good looking, everything you can imagine one can do to BMW has been done already, by more than 1. Every idiot who buys an LS dreams of making it a transformer, but when they realize they cant find bolt-ons and things look difficult, they quit. I think is better that way, I'm glad he didn't keep it.
  19. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
    I have a 97 540i/6 sport, there are a total of 1388 pre-vanos. It wasnt that it was difficult to mod the ls, it was the fact that theres nothing for it. There are very few "bolt on" mods for my bimmer, but I can get low/mid/high cams, low compression/high compression piston heads, forged rods with different stroke, titanium valves, guides, headers, tb, intake mannifolds with various size runners for different applications, superchargers(centrifugal and twin screw), kevlar clutch, underdrive pulleys, custom lsd, lightweight flywheel and driveshaft, brake kits, brake lines, coil overs, sway bars, it goes on and on. Again, I liked the ls, but I didnt buy it to do a motor swap, thats what my MR2 is for. I applaud some of you for doing what you've done(especially Quik LS), but to me, there are more efficient platforms to start with. Stop getting all in your respective boxes over me selling the car. I did at least offer it here, along with additional interior parts, in an effort to contribute to this community that unknowingly helped me fix the problems it had while I had it.
  20. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
    Sorry, I mean a 4.9 modular boss 302, not the stock Windsor
  21. Dustin Kennedy
    13
    Oct 28, 2013
    Cape Girardeau
    Already have, biggest PITA on a BMW. Fortunately I know a bit about automotive electrical systems. Currently tracking down battery drain issues from one of the body modules.
  22. LS6_5SPD
    753
    Oct 6, 2007
    Miami
    That exactly what I mean. It is difficult when you can't get pre developed parts. Modding the BMW is as simple as order online, bolt on, bum.
Share This Page
