coolant leak
Sapperfire
Waco
Sts leaking from the coolant crossover tank, the part under the throttle body that the water pump is in, but its leaking from the gaskets by the heads. :( im gonna tear into it today
its two lil gaskets that you will be replacing its a quite involved job i would advice you to mark all the bolts and make sure you know where they go as there will be lots of different lengths
This is also the perfect time to replace your water pump belt and tensioner.
If you need any specifics on the torque specs or w/e let me know.
