1. As you can see -- we got the software change done. Although there is a lot of work to do still, I thought I would open the site back up. If you encounter any problems -- contact me via the "Contact Us" link on the bottom of the page.
    Dismiss Notice
bench test
Lincoln LS
  1. 92spi
    92spi Well-Known Member
    65
    Dec 7, 2013
    longview, tx
    anyone know of a definitive bench test of a 1st gen DCCV? anything including voltage and amperes would help. thanx.:)
  2. oddball
    oddball Well-Known Member
    1,156
    Aug 18, 2010
    Dallas, TX
    There are a few failure modes: physical break, corrosion/clogging, and electrical short.
    For a physical break, just inspect closely for cracks. I don't think the DCCV has the micro-crack problem, so you're looking for more obvious issues, like a hole.
    For corrosion, you can just momentarily connect the outer pins to v+ while the center pin is grounded. The solenoids should fire, with the plunger smoothly extending and retracting. Close inspection inside the water passages will also tell you plenty. The heads of the plungers should be clean, and the area they contact should be smooth.
    For electrical, the specifications are in the service manual. It's a basic resistance test to ensure the coil windings and connections haven't broken.
    In my case, the difficult to track problem was a driver in the DATC was partially failed and didn't sink enough current to fully actuate one of the solenoids. This took a little more investigation, but there are procedures in the service manual.
  3. joegr
    joegr Well-Known Member LVC Gold Member
    16,209
    3
    Dec 10, 2005
    Gulfport
    You have a test bench that can flow water or coolant through the valve while you are testing it?
    0V is fully open, 12V is fully closed. It is PWM'd for the in between. Also need to verify that there is greater than 10 Mega-ohm resistance between any terminal and the metal cases over the solenoids.
    Seems like it would be easier to test it on the car...
  4. 92spi
    65
    Dec 7, 2013
    longview, tx
    thanx for the info, guys. local pick and pull got a "new" '00 ls v6 auto w/46k miles. pretty well crunched on drivers side, but lotsa good looking parts including a dccv, hyd. fan, etc. just lookin' to the future.....
Share This Page
