a good question
E
ERIC1
Guest
ok what type(not Brand) of antifreeze do you use? what type(not brand) can you use? what are the benefits of one or the other?
driller said:
Has anyone here used NPG+(Non-aquaeous Propylene Glycol) from Evans Cooling?
Yes, back when we used to have "Turbo Tune" back in the 90's and did GN's exclusively. Works great, just a little pricey and if you get any water contamination its over.
Hi Eric
Just the regular green ethylene glycol type always add a system conditioner to elliminate electrolisis, remove dissolved oxygen and lube the water pump bearings.
Regards
Dereck
