2000 conti , ac not cooling well in city driving , on hiway its fine
dfoy50
fort myers fl.
hi all ,
my 2000 conti is not cooling well in city driving on the highway its fine , the freon charge is ok . i have noticed that the cooling fans will not go to high speed , they only run on low . i have looked at the schematic for the car and i have noticed that there is a " ac pressure transducer" listed on the schematic , it has three wires , from what i can tell all three wires go directly to the pcm . does anyone know where this control is located so i can check it . please note it is not the ac clutch cycling control . im suspecting that this three wire device may be bad but i need to find it to check it .
thanks drew
I think it is between the engine and the condenser. Look under the passenger side cooling fan.
