Originally Posted by loveLSE
you can use the template. I purposely took the picture with everything laid down so if anyone that wants to use it can do so.
thanks for the input. I havent done anything for insulation. Im looking into what would work the best. what should I use? If you are going to make it. you need to trim litte bit (see the white bars) it hits the hood. there's a protruding portion on the hood that will hit this area if you dont trim it. |
Originally Posted by sgb00ls
I was wondering if anybody would "recycle" the stock box. At least you know it's going to fit in the space.
Anybody else have another design? |
Originally Posted by 01lssport
As for the stock airbox fitting that big filter, not going to happen. You would have to buy a longer, smaller dia. air filter.
Also autozone sells 3" rubber flex hose (black in color so you can't see it) that retains the shape you bend it to. I used it from the grill to the oval hole in the engine compartment without securing it. Never fell once. Hey surfjaxls, were do you recomend getting abs plastis sheet from? |
I got off work early yesterday and finally put this thing together.
As I have posted before, I used the top of stock air box and some tubing (pic.1) to make an air scoop that brings air from the front bumper (pic.2: arrow) to the hole (pic.3). I made some measurements (pic. 4) then made a template using cardboard box (pic.5). It fits nicely in the spot (pic.6). I bought some ABS plastic sheet and glue at a local plastic store. after few hours of cutting and fitting (I only have hand held dremel tool) I made the box (pic.7). and the final product with KKM filter (pic.8). why no top? It fits perfect and only leaves about 1cm space from the hood so I dont think it would be needed. |
Thanks for the dimensions! That should save a few weekend hours.
Here's pic with dimensions.
they are in inches. as I have mentioned before (but no longer in the thread, now for some reason) I actually made mine bit bigger especially for hieght. I went 1-inch taller then started trimming here and there. I coated the top edge with a paint then closed the hood to see where I need to trim by looking at which part is hitting the hood. It took some time but I like it alot. Hope this will get you all to a good start. Im going to buy a thermometer and test it to see if I get a lower temp. I'll let you all know once this is donw. Im a scientist so I'll have all the appropriate controls so we can all be sure that this thing really works. |
Originally Posted by BDSax
you think plexiglass will be ok??
So anyways I just spent the last hour trying to squeeze the top of the stock airbox modded w/ the 3-inch tubing into the space behind my lower grille. I don't know if it's just me but I couldn't seem to find a way to make it fit in the space. I see that it obviously will fit, but how many things did you have to remove in order to get it in there? Was it as difficult for you as it is becoming for me? I ran out of daylight so I couldn't remove too much so tomorrow I'm going back at it, just don't want to remove things I don't have to so please do tell me how you got yours in there..Thanks in advance.
Originally Posted by lsondubz
Hey make another heat shield for me and Ill paypal you..Im lazy
sorry for late reply.
I was on vacation with no internet access. for me, it toook some time but it went in well. I just removed the bottom flat plastic panel that's covering the engine bay to the front bumper off. it took some sweats. I spent about an hour trying to squeeze that box in there. I dont know if this matters but my bumper is LSE, maybe standard LS bumper is smaller? maybe you can try to trim off the excess plastic on the air box. good luck. |
Originally Posted by GWL
Not having the time or tools needed to do a custom Air Box out of heavy material I thought that I would take a different approach and use foil insulation. The advantages for me are: Easy to make, (scissors for cutting) inexpensive enough to replace easily. Molds to available space. The disadvantage is that it does not look like a custom fabricated air box. I tested it to 95 MPH without problems (time will tell). Before installation the chrome ring on my KKM air filter was too hot to touch. After installation the filter could be handled by a bare hand comfortably. As you can tell I do not have remote thermometers to do an actual test of temperatures. Hope the pictures explain what the setup looks like in the car.
Originally Posted by BIG CELO
loooks real good where did you get the foil from?
Originally Posted by GrayGhost1
George,
That looks very industrious! Is the insulation rigid or soft? The reason I ask is that will it cave in once the intake starts sucking in air. |
George,
14' x 24" roll for 11.00 @ Home Depot
Just so everybody knows, I was originally looking for a double sided foil insulation that was more rigid, however that proved impossible to find in a small town in the Ozarks.
Hey, GWL.
you just need to bring in fresh air by ducting it from the front grill to the hole. Now, your insulation should work much better bringing in colder air from the front and TOTAL blocking of hot air. NICE! why didnt I think of that? Your temp result should be better than mine. |
Welcome back loveLSE, Are you going to make these heat shields, if you are let me know
Originally Posted by BatMobile
Does anyone know if these dimensions will fit the 2000 LS V6 as well as the LS V8? I'm a newbe ...
Yes it will fit.
I don't know about that. There are e few hoses that run behind the head light that caused a problem for me. For the V6 anyways.
Below is a picture of the stainless steel tube and KKM kit on a V6. There shouldn't be any additional "tubing" unless it's aftermarket. When we were making the stainless tube for the V6 we didn't see any hoses or tubes that would get in the way. The box dimensions should work for any LS.
George,
Originally Posted by paulownian
My brother-in-law has a nice machine shop where he builds towable trench diggers, I'll see if he can fab something for us. Can we use a lightweight aluminum that can be bent and cut by machine and then insulated? Let me know if anyone wants me to pursue this. maybe we can tweak the design enough that we can mass market these babies. I have the business savvy; I have a manufacturer; do I have assistance from any members with the design and the R&D?
I have also thought of trying the plexiglass. There isn't any reason why plexy shouldn't be able to handle the temps.
I think in the long run, the aluminum style is going to be best, though. As far as the air flow, my research has shown that the air flow goes top to bottom. We should maintain the same style of air flow that was used in the stock box - from the top front, which would flow over the filter and down to the hole in the bottom left and out the hole in the wheel. I also believe there should be a top to the unit to maintain the correct pressure. I have cut out a template based loosely on the drawing in previous posts and will create an R&D model over the weekend. If this works out as well as I believe it will with these little improvements, we can go to manufacture fairly fast. Thoughts? Comments? |
George,
Originally Posted by 02LSE96LSC91SE84TC
I'm confused, removing the stock filter from the box and then reinstalling a different kind in a box. The whole reason to go to the conical open element kind filter is to not limit the amount of air that the motor can pull. The conical filter has more surface area than the flat filter so therefore can flow more air. Sticking it back in a box completely goes against the design. The design show in this thread looks way to small to allow that filter to breath. The scoop is only going to work so well since as the car speeds up, air starts flowing perhaps past it. Not to mention it only has the 3" tube to breath again. The design is little better than the factory set-up. The thing we're trying to accomplish is keeping the filter from pulling motor heat, sealing the filter from the engine heat is the idea, but reboxing it, is going backwards. I started working on a sheild that will seperate filter from engine and will allow the filter to breath well throu all those large holes around it, but pulling air from the motors warmth will not be an option. It will allow the KKM filter to pull all the air it wants with out restricting.
Originally Posted by J3FF
I'm going to agree...So how about just making an aluminum double-sided wall away from the engine? The air the intake breathes comes from the bottom of the car already, the box isn't going to do much but smother the intake if you surround it. I just thought about that.
We aren't pulling air from the hot engine compartment. We block heat from the engine while allowing the air flow to come from the front of the vehicle.
Didn't say you did, I stated that your still pulling air throu a tube instead of letting the conical pull air more freely in an open space, seperated from engine heat.
It'll look alot nicer under the hood as well! No offense to the creater of the other Fab'ed heat sheild.
Its looking like it'll be a real nice pc. Just Ironic this thread came back to life. I've been planning on fabbing one up like I did on my MarkVIII since I bought the Intake and recognized the benefit it may have. Don't exactly need one in winter. I've switched to driving the MarkVIII as my daily driver a few weeks back and have been letting the LSE be the toy and have been taking it to the 1/4 mile on the weekend, (different thread). Getting real busy at work now so it may take a few days to move to the aluminum.
Originally Posted by jgfish97
Just curious... Is the KKM better than the K&N Typhoon Air Intake System?
I think that could work. NOtice if it stays alot cooler? How about sheilding off the aluminum with something different?
Originally Posted by TheRebel
If anyone is interested in pursuing this further, PM me.
Originally Posted by Kelleyo
Dang that KKM looks nice in your car! Where did you get it?
I work in a design/fabrication shop with all the tools and machines necessary for building anything imaginable.After reading this topic I have decided to begin building myself a heat shield for the KKM on my 03 ls V8 this week. I was wondering how many others would be interested in one? I will make a design using Auto Cad and get a quote for production tomorrow or Friday. Once the prototype is done I will take pictures of it and people can let me know if they are interested.
yes, progress has been made!! I have the cardboard prototype cut out to size and I am going to my work today to cut and bend the metal... I will have some pictures up later today.
sorry for the delay guys... been very busy at work... I have the prototype ready.. just have to trim fit it under the hood.. then off to production... I will be giving it to the fabrication shop on Monday, hopefully wont take long... sometime this weekend look for a new post on this subject, I would like to get a better idea of exactly how many people want a H/S.
I am interested, but it would help to see what it looks like, what it is made from and the approximate cost.
with another post being removed due to the person taking orders through email i would suggesting talking to administrators on this site. i would love to buy one of these heat shields and would hate for you to be kicked off and not be able to sell these since there is such a huge demand for them. please take the appropriate steps towards getting this distributed without stepping on toes
Jelsoft Enterprises Limited.
